Does anyone know the optimal acceleration, jerk,
Does anyone know the optimal acceleration, jerk, and max federate settings for the prusa MK2? Preferably, does anyone happen to know what prusa research uses? It would be interesting to compare that to other printers, and also to use on other prusa variants.
Just in case someone can’t pull the M501 specs for you, you can also check in the firmware here:http://www.prusa3d.com/drivers/
@Griffin_Paquette Thanks. That is helpful, but if anyone has a prusa mk2, it would be super helpful(easier for me) to send M501!! Either way I will post the numbers here once I find them.
Does Prusa use a version of Marlin or a custom firmware?
@Griffin_Paquette Here are the numbers from the 1.0.0 firmware release. I do not know how to pull the numbers from newer releases.
