Does anyone know what electronics would be needed for a "self driving" R/C car?
Does anyone know what electronics would be needed for a “self driving” R/C car? If I’m not mistaken @Brook_Drumm ​ and crew started working on such a car once upon a time but now word about that in a long time.
Can it be based on Arduino and if so what else do I need? I’m totally lost when it comes to electronics so any help is much appreciated. =)
Adapt a arduino zumo robot maybe?
Really depends on what you mean by “self driving”. If you want basic obstacle avoidance, line following, etc, than an Arduino would probably be fine. Even something like GPS waypoint following wouldn’t be too difficult.
But anything more than that, I would say you’d need to up your onboard processing power to at least Raspberry Pi level. For example, using OpenCV to identify objects or hazards.
I am working on APM with my Electromyrmex project, but I don´t know how to make it avoid obstacles. It only drives a pre-defined route using GPS. PIKSI system makes it more accurate, but it doesn´t avoid obstacles either?
There are lots of Arduino based systems with everything needed, but they seems to be all for very small current and power?
Maybe you could use a solution like this? http://letsmakerobots.com/node/27037
If not you could seek more advice http://www.robotrebels.org/
If you have knowledge about C/C++ i can recommend an ESP2866. It has breakouts with up to 14 i/o’s is very quick, has large flash, builtin WLAN stack and can be programmed using arduino IDE. I highly love these things.
I second @Tom_Nardi 's recommendation.
As @Jori_Makinen mentioned, I was thinking of just using an APM flight controller with GPS running ArduRover software. Though I assumed there would be some kind of obstacle avoidance built in once you add sonar or possibly a camera.
http://rover.ardupilot.com
This looks pretty good- have you looked into this?
@Brook_Drumm That seems perfect, it´s just what i want! Allright, let the games begin! :wink:
Thanks for all the answers folks, got some thinking to do now.
Hobbyking has a micro APM board called the HKPilot, assuming space is an issue.
I am working on a self driving RC car based on a standard buggy chasis and a NVIDIA Jetson TK1 board. It has a custom ESC that provides power and IMU sensors, and the Nvidia board interfaces to a webcam for vision processing.
@Daniel_Noree ​ that is what I am going to use too. Please let me know which board you are going to select. I have been thinking APM but I can go for Pixhawk too. If you choose either of those we could do some co-operation with this. I am ordering now the frame parts for the Electromyrmex proto but not yet the control board, because I run the first tests without autonomous features.
@Jori_Makinen ​ I’m gonna need to read up on this before I decide, I’m new to this so it might take a while… :wink:
Don’t worry. I have been designing Electromyrmex frame since April 2015. I have still lots to do with just the mechanics.
