Does anyone know where I can get English Instructions on the P3Steel v4?
Does anyone know where I can get English Instructions on the P3Steel v4? Maybe @Alvaro_Rey_Rodriguez ?
Its not really in English but, its easy to follow http://reprap.org/mediawiki/images/9/9d/Montaje_PSteel.pdf
also tons of closeup pictures at http://forums.reprap.org/read.php?406,569018
or follow the video https://www.youtube.com/watch?v=vQoXe8-sJQ4
LoL I was watching the videos and the second video ended with the heated bed with the wires up showing and glass on top, I might be wrong but should the wires be underneath? Doing that way would cause a gap which isn’t good and if your using a aluminum build plate, it would go “zippity zappity zip zip.” lol
found another assembly manual http://www.kitprinter3d.com/en/blog/p3steel-assembly-tutorial-c10
@Jeff_Dewe its not the same frame.
You got the assembly manual in here @Jaimie_Fryer its not in english but its very easy to assembly
Thanks :slight_smile:
Do I have to paint it? I’d rather keep it looking like the steel frame it is.
If you dont want, you dont have to.
But if you use iron, you should paint it, otherwise your frame will rust. Or you can use stainless steel, that way you dont have to paint
