Does anyone know where I can get some information on the features and controllability that having the GLCD in a Cohesion3D mini will give me?
There is a G+ community for the C3D https://plus.google.com/u/0/communities/116261877707124667493 and a facebook group https://www.facebook.com/groups/1045892858887191/ where you could also ask.
This kind of information comes from the Smoothie firmware side which the C3D is compatible with. It depends on what level firmware you are running and as I recall the docs are pretty sketchy. Try the smoothie forum.
That said, I found the panel capable of controlling all the fundamental functions of the machine which made it worth it to me. This is especially true when troubleshooting or running the machine stand alone as you do not need a host to control the machine.
@donkjr when running the machine untethered do you put the SVG files on the SD card in the controller or on the back of the GLCD?
On the SD card, running from the GLDC is purported to be problematic.
Right on. Thanks Don!
