Does anyone want to have a look at my 4/5 axis CAM?
http://code.google.com/p/simplemultiaxiscam/downloads/list
It seems to generate sensible g-code now.
I’m looking for simple test-cases where it fails.
You can just run that jar file.
There is not much to select in terms of different tools (2 tools) and strategies (fixed for now) at the moment.
second alpha version:
  • fixed number format
  • added support for binary STL files
third alpha
  • you can enter the dimensions of your tool (ball nose or flat nose cutter)
fifth alpha
3 axis milling is now debugged!
I’m having trouble with the G-code emulator, so debugging the 4 axis code is a problem. :confused:
