Does everyone know you can make crazy accurate measurements of layer height, line width, hole diameter, etc. with a (2D) scanner?
Put your part on the scanner and scan what you want to measure at the highest resolution your scanner allows (that’s 1200dpi on my all-in-one but some dedicated ones are 2400 and interpolate up to 9600). On the image below I also scanned a ruler to the left (out of focus because it wasn’t pressed down on the glass).
If you didn’t scan at around 9600 dpi, scale the image with a quality algorithm (Lanczos on IrfanView or default on Photoshop, etc.). I scaled mine up 1000% to 12,000dpi. If you don’t do this, the resolution won’t be high enough to accurately measure in the micron range.
Set your units to mm in your graphics program, and measure away!
You can measure just one line/layer, but if parallel lines seem to visually be the same width, you can measure multiple lines and average them to get a more accurate measurement.
This is much more accurate than you can usually get with a micrometer and you can really see what’s going on. This really helps me dial-in my extruder settings, Z offsets, etc., as well as troubleshooting prints. If you make the image gray (which I did along with gamma adjustments to maximize contrast), you can even pretend you have a personal scanning electron microscope.
