Does FastLED have a way to do plain PWM (either hardware-based or bitbanging) on the IO channels, or is it only designed to work with external controllers? It would sure be nice to be able to take advantage of all the other color and pattern niceties of FastLED even when using plain RGB LEDs.
Oh yeah I’ve seen code out there that declares RGB instead of the clock and data pin. So yes you can use other LED’S of any type. But I don’t think that you would be able to individually assign them(animate) unless they have a data pin. Some do and some don’t just so you know too.
Hi Craig. Have a look at this:
Thanks @marmil , but the biggest reason I want to use FastLED is to avoid using analogWrite. I was hoping FastLED would handle the PWM for me, because I want to customize the PWM frequency but doing so with the hardware PWM messes up lots of internal timers.
I took out all the timer based code in the library 2+ years ago as part of a major round of cleanup/porting (in part because efficiently doing the timer stuff in a cross platform way was quickly becoming unworkable for me), and this is the kind of thing that would be needed to do led PWM without using analogWrite. (Note: even in its earlier incarnation, the library never directly drove PWM on chip, it was PWM’ing shift register based setups and the HL1606)
Of course, in order to do PWM you have to use the internal timers, so you may as well use analogWrite, it’ll be far more efficient. If you do write your own PWM handler, though - you can still use the library to compute/come up with the RGB values you want and just feed those values into your PWM handler.
Thanks @Daniel_Garcia . There are a couple of LED driver chips right now that are in-vogue at several hobbyist parts sites: the PCA9635/PCA9685, and the TLC5947/TLC59711. Do you have any plans to support either of these in the nearish future?
Yes, they’re on the list to eventually support.
Craig, not sure if I am misunderstanding you, but what about using the raw WS2811 chip…
http://www.world-semi.com/en/Driver/Lighting_LED_driver_chip/WS2811/
…you use FastLED to send the digital stream of pixel data to the strip as per usual, but then you have access to the 3 individual output signals on the chip which are called “OUTR”, “OUTG” and “OUTB”… these are each the PWM signals that I think you are asking about. From memory, these outputs are 20mA constant current sources (maybe sinks) so if you dont want to drive a 20mA LED per usual, then just stick a resistor there and you now have access to the PWM voltage signal. Does that answer your original request or did I miss something? thx and good luck!
