Does laser web 4 have the ability to save individual laser location presets like
Does laser web 4 have the ability to save individual laser location presets like corellaser? If so how?
Not that I know. But you can type direct coordinates.
Now can you explain how is you process and how you use it maybe it’s a good idea to implement
On corellaser you just move the laser head where you need it and click save, then just name the position.
You can set macro buttons to do that.
How can I go about doing that?
#RTFM
See settings/macros
@cprezzi ​ is correct, great use of macro for that
@L_Y11 ​ look for info at http://cncpro.co
I’ll def look into the macros thank you
I haven’t played with macros in LW4 yet, but in LW3 I had macros set up for “Top-Left”, “Top-Right”, “Bottom-Left”, “Bottom-Right”, “Centre”, “Rail Access” (to have it go exactly where I needed to access the x-axis belt tensioners). Reasonably simple macros. E.g. Top-Left (G0 X0.000 Y0.000).
