Does the K40 cut better through ply or is it the same for hardwood.???
Does the K40 cut better through ply or is it the same for hardwood.??? How many passes is it needed to cut 6mm hardwood? I can cut 1/8 ply at 8mm sec @ 7ma any thoughts thanks
I have never tried, but would be interested to know if it is possible too. When I cut leather, I notice that thicker stuff (like 3-5mm thick) requires either a lot slower, a lot more power, or many more passes in order to cut through it. You may find it to be similar with the hardwood.
I did 1/4 inch oak at 5mms with power at 15 or so. 1/8 inch birch cuts easy at 15mms at 11-13 power. I really like cutting the birch and poplar the best. Poplar gives a nicer contrast on the engrave. Avoid knots in solid woods. I have some black walnut I plan to test sometime today. Will update.
