Doing quite a lot of experiments, and learning.
First, I built model airplanes, as a kid. Plastic is a kind of lousy material for building flying things. Too heavy, and not strong for weight. Still, possible to make complex shapes, not practical with other materials/fabrication. In particular, single wall FDM prints allow light and stiff structure with little material. Also allow more complex and interesting aerodynamics. Enough to make up the difference?
Also experimenting with larger nozzles. Did the first year of my learning curve with 0.4mm nozzles, as that seemed to be the consensus recommendation.
But … I do mostly functional / structural prints. Have printed exactly one figurine (of Naomi). Interested in function more than pretty detailing.
Swapped in a 0.8mm nozzle, and … interesting.
First, I am discovering the thermal limits of hotends. Put simply, the usual 40-50 watt heaters seem to be a limit. (Very much want to get a Ubis hotend, in time.)
With the 0.4mm nozzle, the physical limits of the printer in terms of moving around the nozzle seemed part of the limit. Was unclear that the hotend was a limit (though was at least in part).
With the 0.8mm nozzle, at the same rate of travel, and the same profile, there is 4x as much plastic extruded. Rate of travel while extruding is limited to about 30mm/s, or the extruder starts skipping. I believe this is strictly a thermal limit in the hotend.
Also, I expected cruder results with the larger nozzle. Got some prints so smooth as to foul up my camera auto-focus. Very much becoming a fan of larger nozzles.
Note that I am using a stronger part cooling fan than stock, and a better duct design to direct the airflow. This was needed for good result with the more complex single-wall prints.
The large rocket is an easy print and 388mm tall. Takes about eight hours at 30mm/s with 0.5mm layer height and 0.8mm line width. Pushes the TronXY X5S printer close to it’s advertised limits (nominally 340mm x 340mm x 400mm). The short version is that print bed design is inadequate. Past 300mm in height, and the bed shifts under the print. (Examine the nose of the rocket.)
Note that I added structure to the underside, to stiffen and flatten the print bed. Seems the two leadscrews, four smooth rods, and sleeve bearings used for Z-motion have a certain amount of “give”. The normal printing force of laying down plastic are enough to make the bed shift. (The print is in effect a 300mm+ lever in this large and stiff object.)
I had doubts about this design for Z-motion, but that was just a guess. Good to put things to empirical test. Also good to know my doubts were justified.
With modifications, the TronXY X5S is a cheap printer that does well enough within a 300mm cube. Note that I am only printing with PLA, at present.
The glider is 600mm from wingtip to wingtip, and from nose to tail. Needs five prints of a larger printer, and is a challenging and much longer exercise. The tail and wings are single-wall “spiralized” prints. The total weight of the final version was 380 grams, of which about 100 grams (or more) could be “payload” in the nose. Not bad compared to other folk’s printed-plastic designs (maybe a notch better?), but still very heavy for a flying model.
What worked very well was using compound curves in single wall prints. This allows light and stiff structure, with interesting aerodynamics. (The appearance is the end result of functional choices, not aesthetics.)
The 3D-printed glider did in fact work, but is not going to replace balsa.
