@donkjr I’m a little confused and wondered what your experience is with flybacks. My 6 month old Lps packed up a couple of weeks ago and I’ve been in conversation with the supplier, they are sending me a new one.
The symptoms with mine is it will not fire from the test button on the machine nor the grbl shield I now have, but with the 6 pin plug pulled out will fire from the test button on the lps. Do you think the flybacks has gone or could it be the internal connections that are at fault?
That is a definite sign of a short somewhere. I would look at the simplest start which would be your limit switches. They use the same 5 volts that is used to enable the power supply.
I thought about a short but didn’t know where to start, I take it you mean the 5v from the lps. My limits are fed from the R4 Arduino Paul supplies with the gerbil shield which in turn is powered from a seperate 24v PSU.
I would start then from disconnecting each power supply separately, and see what happens.
I would focus on why it will not fire from the test button on the panel.
If the test button down on the supply fires the laser the LPS would seem to be good.
You said: but with the 6 pin plug pulled out will fire from the test button on the lps.
Does it fire from the test button on the supply when the 6 pin plug is plugged in?
…something on the 6 pin plug is holding the control signals from going to grnd.
Check your supply using this guide and let us know what you find:
https://drive.google.com/open?id=1yAGfqw3VVKW91qEpCVFOuAwYoyI7PPuh
@HalfNormal basically the only way I’ve managed to get it to fire is with the H L P IN G 5V plug pulled out. The problem can’t be the gerbil because I’ve tried both new boards that I have here.
Due to this I’m guessing it’s got to be an internal problem with the lps.
@Andy_Shilling all things are possible with a K40. But I would be surprised if it is internal to the LPS.
Most times there is a problem with the wiring or the panel connected to it.
Did you try the troubleshooting guide and did that find anything wrong?
@donkjr yes Don if the 6 pin plug is connected it will not fire, even the LEDs on the lps will not light up when powered on; remove the plug and it will fire from the test button on the lps.
What I’m thinking is the same as you, I’m going to remove all connections from the 6 pin other than the arm and test button to see if that makes a difference, if so I’m sure that will denote an earth problem but the question is why 2 weeks after fitting the gerbil shield.
@donkjr sorry I’m running a answer behind you lol, the only trouble shooting I’ve done so far is what the seller requested, I’m like you in the fact I don’t believe anything is broken until you know it can’t be fixed.
I will do some testing later when I’m home and let you know what I find.
@Andy_Shilling if the LED on the LPS is not lit (depending on your supply type) that suggests the 5V is not working or perhaps it is shorted to gnd by the connector.
What is connected to the 5V on the LPS?
Off the top of my head I don’t think I’m running anything from it, I was using it to power my laser pointer but I’ve not fitted that since preparing it for a 60w tube and renewing my extraction system.
@Andy_Shilling picture of LPS with the LED’s showing pls.
@Andy_Shilling then one of the 5V connections on the 6 pin is shorted?
If your remove the 6 pin connector does the LED come back on?
Forget everything lol I decided to have a quick look inside before possibly charging up the flyback and I could see a bad solder joint around the 5v connection. It looks like as the plug was pushing in to the socket it was enough to create a gap. I have just resoldered it and it seems I am back up and running.( I’m presuming this was the problem).
Thanks for your help Don I think I’ll be more investigative next time something goes wrong then I won’t have to bother you quite so much.
@Andy_Shilling never a bother glad you are running again!
@donkjr cheers pal, bonus of the story is I’m getting a new 60watt lps free of charge. Can’t knock that one.
What am I? Chopped liver?
@Andy_Shilling
@HalfNormal needs some kudos…
He said first: That is a definite sign of a short somewhere.
@HalfNormal I am so very very sorry kind sir, I got so excited by the thought of being able to cut something again I totally forgot you. Please accept my apologies.
@Andy_Shilling no worries. Just wanted to make you squirm! I’m just glad that you are able to get your system up and running again.
@donkjr you forgot I was the first one to say it was probably something to do with the 5 volts too.
