Don't know if it will be any good but this is the new cutting
Don’t know if it will be any good but this is the new cutting bed i made i just have to put some bolts in the corner for legs
This is looking good man.
Is that all galvanized steel? I’d be careful about the fumes you’ll generate from pass through if so. It won’t be as much as if you were trying to cut it, but there will still be some. http://www.laserworx.com.au/laser-cut-galvanized-steel/
Yes it is galvanized
Just wondering how are you planning on getting that bed to the right height.
I’ll be posting pix for that soon
By the looks of it, your bed is still a fixed height. So unless you plan on burning material of the same height, you’ll most likely need to raise/lower the bed.
Check out the adjustable Z tables. :wink: Maybe you can mod those bolts your using for legs?
Its just sitting in their so its easy to get out if i need to but at the moment im just looking at doing the same stuff i was before i have been looking at some z axis tables and how to make tham i may play around with it
what is the size of the bed that you are making ?
I don’t know the size i just used the string and made it based on the size of the original bed but when I went to put it in i had to take 1 bit off to make it fit
I’ll try to find out the size next time im in the office
@Justin_Nguyen 35cm x 30cm is the bed size
Thanks @beny_fits
