Doubling steppers not working?
Is there a reason why using the stepper doubling would fail with two doubled steppers? I’m trying to double the X with alpha and delta, and Y with beta and epsilon. I removed the ‘extruder_’ references and ensured only the current is set for the slave stepper settings, but only one stepper moves for X and Y. I checked the jumper ribbon and the steppers, and there’s no physical connection issue. And I verified the pins for delta and epsilon are working
