EDIT: Vector slicing is the way of the future for craftware. They’ve got it even faster than raster slicing due to building this program from the ground up. This program has a promising future.
While it’s still very much in beta, craftware is doing some very interesting things with slicing. Firstly they had a ‘new’(can’t verify this) method of slicing called raster slicing. There were heaps of parameters you could tweak but it still seemed to have a couple of small issues so they re-introduced vector slicing which is apparently the standard slicing method. They’re going to continue working on raster slicing in the future as it cuts slicing times by a siginificant margin.
While it isn’t open source (they said it should be in the future) they are using community advice to build it. It excites me when you can ask for a feature and see it implemented a few weeks later.
Tom,
Surprisingly the 2 skull test scene was sliced faster with our highly optimized vector slicer than our “old” raster slicer. We don’t use 3rd party libraries in our software and the code is highly optimized. We won’t continue the raster based method, but still most parameters can be used with the vector based one.
@Craftunique1 I didn’t realise you guys were on G+. There’s a community/knowledge base here just waiting to be tapped into if you’re trying out something new. At the end of the day it’ll be people like the ones it this community buying/selling your products. Sorry bout blurring some facts. I’m very excited for the future!
I never looked at any slicer software code, but I wouldn’t have expected anyone to use raster methods to slice for FFF because of how the machine operates. Converting a vector object to raster slices to a vector path sounds like an exercise in pain.
I was playing with the 1.06 version. So it’s not the latest version now. I believe it was the time delay between layers that caused the problems. I entered 0 seconds for minimum layer time but it would still pause after each layer and ooze extra material every time it paused. My round cylinder had warts all over it even on the hole through the center.
