(edited to add that the current Smoothieboard config.txt posted on github has two identical
(edited to add that the current Smoothieboard config.txt posted on github has two identical sections to enable limit switches, one starts at line 223 and the other at line 241 - is this intentional?)
I’m trying to enable end stops for a Z-table and running into some unexplained issues. The board is running the stock firmware-cnc firmware as well as a stock (Smoothieboard) config.txt from smoothieware’s github (with gamma_max_pin enabled.) In config.txt, I set gamma_limit_enable to true (and removed the # at the start of the line.) With a switch connected, pronterface reports P1.29 as 0 (zero) or 1 when I manually depress the switch. Great, it sees it. Now here’s what happens:
Boot up the board and try to jog Z (either positive or negative) and it instantly halts. Pronterface responds with: ALARM: Hard limit +Z
I can issue a reset (M999) and try to jog again and now it does jog, no alarm, however manually triggering the switch does nothing.
At this point I thought, ok maybe it’s something with the switch itself, so I removed it completely, yet left them enabled in config.txt. Reboot the board, connect to pronterface, try to jog Z and it instantly halts, same alarm code. Once I issue a reset, I can now jog Z just fine.
Tried a different approach: boot up the board, I can jog X and Y no problem, tried jogging Z and it halts again. Issue a reset, and now I can jog all three axis.
Now for the 4th attempt, where I reconnected the switch. Boot up the board, jog X and Y successfully, tried jogging Z and it halts. Issue a reset, now I can jog all three, however the switch does not appear to have any effect what so ever.
Anyone have any suggestions of what to try to debug this?
Continuing on this, on a whim I tried Z-min, lo and behold that works as expected. With the switch normally closed and M119 reports a value of 1. I can jog Z and manually trigger the switch and it halts. Great. However, doing the same thing on Z-max and nothing happens when I trigger the switch.
Also, it still instantly halts when it first boots up and I try to jog Z. But after a reset it works fine, and the end stop triggers for Z-min only.
config.txt shows
gamma_min_endstop 1.28^
gamma_max_endstop 1.29^
gamma_limit_enable true
