@Elias_Bakken I see the Redeem code supports a filament sensor. I am currently using the Tunnell sensor that does all the work but I like the idea of the code being in control since it knows when it should be extruding. The replicape doesn’t have any extra i/o and I see it is using the event subsystem so is it setup to use mouse or something?
It’s very experimental, but it does work . I’m using two end stops as input for a rotary encoder. I’m not sure how to integrate it into octoprint, though. Currently there is an Mcode for seeing the “drift”, but I want a continous feedback like with temperature. Would be great to calibrate tension on the extruder I think!
