Endstops Trigger Each Other
I’ve been searching the internet and the 3D Printer guide for any hint of a solution to this problem, but I cannot find anything. I have an odd problem with my end stops where they appear to trigger each other. Whenever I press down a single end stop and send the M119 command to my board to check the status of the switches, all of the end stops appear as depressed even though only one is activated. Once I release the end stop, they all return to 0. This behavior occurs for my x, y and z end stops. I am using an AZSMZ mini board, and my end stops are inverted in the configuration file because they were appearing as depressed when they were unpressed.
Thank you in advance for your time and help!
sounds like a wiring error. can you posts some pics?
You are right, it was a wiring problem. After a bit of investigation I realized that I had switched two of the wires in my connector housing, improperly connecting the switches to the board and sending the wrong signal. I connected the wires in the right order and now the switches work properly.
I started having the same issue after loading the latest edge firmware. I’m using an Azteeg x5 pro to drive a delta.
