I recently started using Simplify3d (it’s about time, I bought it months and months ago). My Z direction was not right. When I pressed up on the z axis to make it go up it would go down. It was brought to my attention to swap the wiring on the z axis going to the Azteeg X5 Mini. I did this, but now when I press Z home, it doesn’t go towards the end stop, but up and down are going the correct direction.
Don’t think about it as up makes the bed go down. Think of it as up increases nozzle to bed distance, down decreases nozzle to bed distance.
As far as upgrading smoothieware, I think it would be a good idea. But keep your old firmware.cur, config, and config-override files. That way if you have anything you don’t like or have problems you can just go back.
Do note that the newer firmware requires the newer config file. It shouldn’t take long to edit it. But just be aware you can’t use old config with new firmware since several things have changed or been renamed.
i believe if you look at the controls in S3D its non directional but more… graph and plot like. ie + and - as well as number values. as there technically is no “up down left right” its all relative to the extruder i believe and where it moves to.
(Which version will depend on what version board you have).
You will need to hand edit it. Just open your old config, the new config, and your config override file. It gets pretty clear what needs to be added after that.
@Eclsnowman Thanks Eric. When you say I will need to edit it… Got anything I can compare my config file to? Also what needs to be on the SD card? Just firmware.bin and config.txt?
Yes, http://firmware.bin and the config. I would just compare it to your original config, or the one on the GitHub. Also if you did PID tuning originally then look in your original config-override file. It will have things you modified via gcodes and saved via m500.
