Even Adobe Illustrator can struggle loading SVGs:
Illustrators given me nothing but trouble for laserweb. I’ve pretty much given up on using it and switched to inkscape for generating svgs for lw4
is it really slow generating? in mine it takes forever to generate the gcode and makes me skeptical whether it’s good or not. trying to do mill pocket from an svg
It depends on the SVG. Some generate quickly.
probably my issue, I’m practicing with a Jack Daniels image. pretty complex and I set a 4mm bit
oops
btw, amazing program, takes a lot of cpu to run but way easier than mastercam and trying to figure a way to “select all” in fusion360 is terrible.
