Ever wondered how to make a perfect 3D printer object? Is it even possible? Yep, you can get nearly flawless result by finishing your printed parts with certain technics.
My buddy Sohrab and I decided to share with you our humble knowledge about them. Turns out it was literally a blazing idea
Watch the second part on Geeky Sohrab’s channel! - http://youtu.be/CaK71rU6xCM
http://www.youtube.com/watch?v=RWdJloH5_bw
Good job El, remember you have plenty of time to explain things so you do not need to speak quickly
Something else you might consider is to pre-setup your shots, when you go back and review it you see that during the entire ‘rafts’ discussion your piece and the work you are doing on it is out of focus because your auto-focus video camera is focused on the laptop behind the work.
@Chuck_McManis Thanks, I’ll try keep in mind next time we will have so much fun making video
Nice and smooth. Would it be possible to do it outside and with less flame. Fire Department you know.
Usually it’s a bad idea (and example!) to use water to extinguish burning liquids
