Ever wondered, how to show more than one animation on the same leds?
Here some simple code showing a video cross fade between 2 animations running at the same time. Try it out: https://gist.github.com/StefanPetrick/0c0d54d0f35ea9cca983
http://www.youtube.com/watch?v=MOoyy-1cNSs
Super example :slight_smile:
like a boss!
SICK! I’m going to try this now!
#1 runs out of memory compiling over 144 leds
#2 Not sure what pin to use tried all of them don’t work…
@Scottie_D369 What micro controller are you using? Since a block of memory is set up for not one, but three leds arrays, memory could become too large for a low memory controller, and even more so when specifying a large number of pixels.
@Scottie_D369 #1 3 CRGBs mean that you need 9 Byte of RAM for each led. With an UNO (2k RAM) the code should work up to 100 leds.
#2 The code says data = pin 7, clock = pin 14 (Hardware SPI on Teensy 3). You can change this.
@Stefan_Petrick What diffusion material are you using there?
@David_Brailovsky It´s toilet paper.
Haha, nice :slight_smile:
