I’m in need of some help with my external drivers.
I am using the ST-7128 stepper drivers from stepperonline. I just switched to Smoothie from RAMPS, and on RAMPS they worked quite nicely. On Smoothie they seem to be doing nothing.
So far I have tried wiring them in the two modes suggested by the wiki (common cathode and common anode). Neither of these seemed to work so I searched the internet for others with a similar problem. The main suggestion I found was changing the timing - so in the config file i changed microseconds_per_step_pulse from 1 to 10 and several higher values. Still no success.
Recently, for a project in a class, I had to wire this stepper driver up to a National Instruments Data Acquisition device (DAQ), and I had some trouble there too. with that I was using a 5V power supply that outputted 5.07 V. I was using the DAQ to control three transistors that would in turn control the inputs on the driver. I found that using 2n3904 transistors didn’t work, but tip120 transistors did. This leads me to believe my problem lies in some quirk of electronics that I don’t understand.
I’m open to any suggestion. Whatever gets my printer running again will satisfy me.
Maybe the smoothie’s 3.3v is not enough ? And you’d need a level shifter to bring it up to 5v ?
I ran into some issues this past weekend hooking up ST-6600 drivers to my smoothie. In addition to the configuration in the wiki (I used the common anode setup), I also had to invert (place a ! after the pin) both the step and the enable pins. After that my smoothie controlled the steppers perfectly.
Yet again, I’ve fried another stepper driver, this time on my smoothieboard. Don’t ask how. I’m planning to replace the stepper with an external driver and have a couple of questions:
- The stepper driver that failed is on M3. MY board is a 4XC. Can I connect the new stepper to connectors on M3? I understand that the config needs to be changed to indicate it is an external driver (insert “o” after the pin designators).
- I ordered this from Amazon: by AMX3d: 20KHZ CNC Single Axis 32 Segment Upgraded TB6600 Micro Step Stepper Motor Driver Controller. Will this work, do you think? Here are the specs:
20KHZ CNC Single Axis TB6600 2/4 Phase Hybrid Stepper Motor Driver Controller
Features:
9V-40V DC power supply
H-bridge bipolar constant phase flow driver
Up to 32 segments of six kinds of sub-modes available
High Speed optically isolated input signal
Standard common anode single pulse interface
Built-in thermal protection and over-current protection
Note:
This driver is the upgraded version TB6600, heightening segment to 32 subdivision, suitable for high segmentation applications.
For step motor: 42, 57, 86 type 2 phase 4 phase (4 / 6 / 8 line)
Thanks for any advice!
I did some playing around with it and the one thing I found that seemed to work was using Ethernet instead of USB to connect to the Smoothieboard. After this I had to change the timing (microseconds per step pulse) to prevent skipped steps. A value of 7 seems to work best for my drivers.
