Final Patterns for YUM sign 2015:
Hello FastLED,
I finished up the pattern programming for the YUM sign in time to send it off to sunny Sacramento last Friday morning. It will then make a short journey to Black Rock City where, hopefully, a few of you will be able to see it and perhaps try the YUM cart experience.
First off, thanks to @Mark_Kriegsman for creating the overlay code. It looks great and adds just the right amount of unity to make all the patterns work together.
As for the patterns that I added, there are three: 4 random color chase, rainbow with darkness, and warm goo. The code is mighty ugly, I must clean it up a little before I post
I took some video of the final settings before it was shipped off. I have asked my friends to send images and video of it on the playa. I will in turn post what I get when I get it.
Cheers,
Matt Richard
http://www.youtube.com/watch?v=Go1GfPgp5Yc
Fantastic! Looks just great!
Is the cat included in the display?! Because that’s awesome
Great work, very inspiring
Thanks everyone
@Jarrod_Wagner that’s Morty, he has been rather fascinated with this project. Though I suspect it has more to do with the cables then the lights.
@Tom_Shea I am not using a diffuser for the LEDs. Instead, I mounted them perpendicular to a white surface that reflects the light outward. However, a few of my favorite diffusers are: sanded white acrylic, white solid surface(Corian), and Tyvek.
White acrylic is reasonably cheap, and very easy to laser cut. After cutting it give it a good sanding with an orbital sander using 220 grit discs. You can tap acrylic using a cheap tap set from amazon and make a nice finished product. If you can’t find/buy white acrylic, you can sand the heck out of clear to get a diffuser. Its not the same, but it can work. A great place to find scrap of this is outside of fabrication studios. A lot of places that make displays for big retail stores use a lot of this stuff and throw out there scraps.
White solid surface( Corian ) is expensive but gorgeous! It just glows so nice and feels wonderful in your hands. It can be a pain to work with by hand, but you can CNC route it relatively easy. I get leftover pieces from here: http://solidsurface.com/sheet-material/overstock
Tyvek is very cheap, super thin, light weight, and holds up out doors. However, it is not at all rigid and closer to a fabric in material properties. It also has an almost tie dye texture to it, which can be nice.
