Finally got my ShapeOko going again. I upgraded from GRBL 0.9a to 0.9i, which meant I needed to do a bit of rewiring inside my control box to swap D11 and D12. I took the opportunity to clean up all my wiring so it’s a little more movable and safer. Since I was last running CP probe support has been added, so I wired in a touch probe too.
Good News:
- Using a touch probe inside CP is super easy.
- Everything mostly works after reassembly
Bad News: - Spindle enable commands don’t seem to work for me (yet)
- Skipped steps on Y axis
So I air-printed the CP sample a couple of times, and it looked OK. When I ran it for real, it ended up skipping steps on Y. I did not have the spindle cranked wide open, it was around 66% so I may have not been spinning the mill fast enough. And it only shows up on Y because that’s got the longest movements. (?) Or I need to increase the current on my Y stepper. Anyhow, Success!! It’s so nice to come back and see all the new features in CP.
