Finally got the drop down button on the top right working correctly. My little widget now shows the correct Fork URL. Yay for open source maker movement.
Now, onto moving the USB camera I have onto the z axis so I can perform vision based work compensation. i.e. if my work piece is not parallel to my axies, I want my machine to know and compensate.
Is there existing G-code to assit in this matter? e.g. defining a work coordinate that is not parallel to the axes.
Just checked out your GrblLaser widget. That’s really great. You’ve got it fully documented with your pubsubs. You are also the first one to pull off a Github-based widget.
Yay me. Now onto more chilipeppr improvements. I might want to change the name to more generic in the future. After all go scale, spindle controls are applicable everywhere.
