Finally I got my Ultimaker 2
I highly recommend to make an acrylic door. You can 3d print hinges from here: https://www.youmagine.com/designs/hinges-for-ultimaker-2-door
They would reuse the bolts from Ultimaker frame (may be, you will need to use slighly longer m3 bolts for that), and the door will rotate 270°, which is pretty convenient.
In my case, the door is also kept in the closed state by a small neodym magnet, but it’s trivial to figure out, when the door is there.
Welcome to the UM2 family!
Thanks guys I want to do everything at the same time hhhh
