Finally installed @Walter_Hsiao 's Mini Space Invaders Carriage with 40mm Fan. The bushings from my original carriage got loose an fell off during a print so I installed the carriage that has been half finished for quite some time. It’s printed in ASA-X. This carriage is higher than the original, therefore I had to modify the Z-axis support to allow the bed to reach the nozzle (one screw head touched the Z-shaft mount). I might redesign the Z-end stop switch mount as it had to be twisted to move up the switch high enough. Part cooling fans are ordered. Does anyone know how they are fixed? Glue?
