It allows you to take your sketchup output and turn it into an svg. I’ve only used it simple objects, but it seems like it might work with more complex models too.
Second, is it possible to search anymore? I want to see if anyone had posted this but the search at the top of the new google plus seems to search everything not just the group.
The latest version (thanks for that) installed the .rb in the plugin directly but does not show up in the extension directory in SU and does not show up in the SU ui??? ideas?
Thank you that worked. It installed like this /SketchUp/SketchUp 2015/SketchUp/Plugins/sketchup-svg-outline-plugin-master. I moved the “contents” of sketchup-svg-outline-plugin-master up one level and it works …
