First run of the Megapixel Controller powered by a teensy 3.2 receiving 32 universes
First run of the Megapixel Controller powered by a teensy 3.2 receiving 32 universes of data (e1.31) and using fastLED version of octows2811 outputting to 8 pins. The green status led is indicating that it is framing (each time led show is called).
I want more info on everything I saw. You got a blog or something on this. I think I want one. My kilo-pixel controller don’t look too pretty :slight_smile:missing/deleted image from Google+
Looking good. Have you run into any issues?
Not yet Marc . The rj45 parts I ordered are the wrong type so the octows2811 pin colors are reverse (should be orange pair first instead is brown pair first). I will need to get the correct rj45. Functions perfectly but trying to stay consistent with octo…
@Gibbedy_G megapixel.lighting its not ready yet but will have everything there with code and options
