First time using smoothieware coming up! @raykholo makes some nice,compact, and seriously well designed boards. I’ll test this one on the G-Rap Jr. at first but will for sure be using it in the delta build.
I may have a heavy use for this, can you provide further information (links etc)?
@Rene_Jurack contact @raykholo directly. Definitely awesome desing
@Rene_Jurack best thin to do is contact him directly like @Ariel_Yahni_UniKpty said.
Does ether net connecotr supply enough current?
Yes @raykholo has being using this for a while now
Thanks guys.
@Rene_Jurack Small printer requires small board to run it?
This is the mini, it has 4 swappable stepstick drivers, 6 endstops, 2 thermistors and 2 normal mosfets for running a hotend and heated bed like the mk2 (8 amps no problem) + 2 tiny mosfets for fans/ LEDs and whatnot. The white connector on the left is also for the ribbon cable on a K40 - this is used to upgrade those machines, but is also good choice for 3D Printer/ CNC Mill/ other machine type. GLCD and wifi control possible thru expansion modules.
Interesting board!
How is it?
@Olivier_Bilodeau haven’t had the opportunity to put in in a printer yet but it’s very well built. High quality components and so crazy small. About the size of an arduino Mega 2560 and pretty much equally compact
@Griffin_Paquette and price wise ?
@Olivier_Bilodeau it will be $79 which I think makes it an extremely good value.
Wow! And I’m currently looking for a smoothieware compatible board
Any store for the boards ?
No store yet, we are currently in the final testing phase and I make the boards by hand. If we can get some orders at once, I can order 100 units from the factory. I will get an info site up ASAP.
Where would it ship from?
I’m in USA, not too far from New York.
Nice! My sister lives in Waldwick, North New Jersey, I may get free shipping to there!
Cool, that’s less than an hour from me. Shipping there would be cheap. Where are you located?
I’m back to Brazil now, but once in a while I show up.
