First wood carving attempt. Nothing fancy just used a cheap 60° engraving bit and a design from the internet, and fusion 360 engraving toolpath.
Where does one find things like that?
The design I found by an image search “koi yin Yang”. Then I converted the black and white image to a DXF file to import into Fusion360. I use Inkscape for the image to DXF conversion. There’s a number of good tutorials on YouTube for using Inkscape to convert any image to a vector based image sick as Svg or dxf
@Darren_Lee Thank you. I’ll check it out.
Great process @Darren_Lee have done this before. You guys are kicking out so many great carvings!
