FIXED! I will try to ask here as there is a lot of people
I think what you see is the difference in with and height of the laser beam. It’s not an ideal round dot, it’s more of a oval.
LW3 does not compensate the laser kerf (cut width). in LW4 you have the option to select a “cut outside” operation which will compensate the beam width.
@cprezzi ok maybe is a good time to switch to LW4
:slight_smile:
@cprezzi ​ i think i leave it there :slight_smile: … thanks for the tip that was the solution (cut outside) … now I must address the rest of the ‘problems’ that I didn’t have with LW3 … for example in the non cutting move’s the machine moved too slow and I didn’t find any setting for this…
Anyway thanks for the tip
The default for travel speed for Smoothieware is usualy defined in config.txt on the SD Card, but can also be changed by a G0Fxxx (mm/min)in the gcode (or via Console).
