I will try to ask here as there is a lot of people with good knowledge in laser cutters…
After i have almost finish with my custom 50w laser build i have make some test cuts … the pieces i cut was squares and circles , in my X axis i am dead right in my measurement but in my Y axis i am off about 0.2mm.
I have measure my Y axis distance with dial gauge it was right … i have fire laser dot in distance from 0-10, 0-100, 0-200 mm is dead right … but when i cut a piece i am off … Any thoughts why is this happened ??
@Kostas_Filosofou you measured the cut piece and it was off .2mm from the design?
Is it off this amount on both sides? Edges are often not cut square.
… .2mm is not a lot?
@donkjr exactly was off about 0.2mm of the design … but only on my Y axis … yes i was measure both sides-edges of the piece … I know is not that match …but you know …
I was searching in the web now and a find a article that says maybe is the mirror alignment the problem … as i am sure that i am 100% center i’ll check it all from beginning on more time ,maybe i miss something
@Ariel_Yahni_UniKpty Thank you I have already see some of your videos …good job by the way! definitely i watch it again when i start the learning procedure
@Ariel_Yahni_UniKpty i have already check my steps … as i mention in my post i have measure manually ( i move the axis 1mm-10mm -100mm throw the LW) with my dial gauge and i am ok
