Follow-up to my previous post where René Jurack asked to see the finished print.
Follow-up to my previous post where @Rene_Jurack asked to see the finished print. :slight_smile: I’m seeing some slight under extrusion, but it will be primed and then painted, so it should still work well. There was a third piece with thin 3" spikes that didn’t print well. My friend is going to re-design that piece. This is ABS, 0.1mm layers, 65mm/s. No brim or raft.
The plate is for the rings?
@Rene_Jurack The bottom of the “H” will attach to the two protrusions on the top left of the plate so it stands upright.
