Today I disassembled the extruder, hotend, fan and z probe and mounted the new version on the y arm.
The food extruder is screwed on with a delrin plate. Unfortunately the delrin plate does not match properly to the y arm. I don’t want to redrill the y arm so I’m thinking about printing this plate. Are there STL files availlable?
I’ll get the model posted ASAP so you can do whatever you need. How far off is the plate? We built a bunch of printers with the paste extruder attached do I know this run was good… Not sure if you got a bum part or what
@Brook_Drumm I’ll take a closer look tomorrow and replace the plate right away. I was able to mount the extruder but I had to swivel out the heater block.
