I’m not sure that Slic3r allows for this action, as easily as Simplify3D does, but the concept is simple. I’ll describe S3D first, and you can decide if the manual method is worth the effort.
Within the advanced settings of S3D, I can set a start and end layer height for a specific set of print settings. For the first collection of settings (process 1), I would have the outer layer thickness set to normal, ending at, for example 25 mm height.
For process 2, all the settings would be identical, but the process start would be 25 mm and have the outer layers set to zero, stopping the process at 35 mm for example.
Using Slic3r, unless you can find an automated method, consider to chop off the model at the desired height, generate the g-code. Reload the model, chop it off below the previous location and above the second spot, generate g-code. Reload the model, chop it at the second location, generate g-code. Open the three files in a text editor and splice them together.
All references I’ve been able to find specific to Slic3r for anything similar to this seem to point to variable layer height and allow no capability to embrace your objective.
I’ve used Slic3r on occasion and am aware that you can position the model “below” the print bed to create the slicing I’ve described. I cannot recall if it can be done with the precision necessary to manually stack the pieces.
I suspect that you can achieve accurate model segmentation within Fusion 360, however. I’m comfortable enough with Meshmixer to say that it can be done with that program as well.
Please note that my suggestion results in a portion of the model in which the infill is visible around the entire perimeter of the selected segments.
I hope you are successful and I would enjoy to see a photo of the result.
