I just ordered a smoothieoard to drive my new CNC hotwire foam cutter. (And to use it later in a real CNC mil)
I know I won’t need a full blown CNC software like Mach3 because smoothie will run the Gcode for me.
But how is the workflow going to be? I would not want to interact with the serial console and paste gcode myself.
The frontend softwares mentioned on the front page seem all very 3d printer centric.
I really would not mind having he tool axis plotted during a cut and at least some manual control options for homing axis and such.
And if a four axis foam cutter is too excotic with it’sgeometry. How would normal CNC mils be driven with smoothie?
Hm, looks like the tool world isn’t quite as barren as I thought. I forgot that smoothieboard is GRBL compatible.
I found grblfeeder. It’s not pretty but better than nothing.
I would still be interested in your replies.
You have many options. But as far as I know, nothing that will be as complete as what you get from the Mach3 interface ( live visualisation of the tool’s position/path etc ).
As you mentionned, the GRBL controllers should work ( though a few do stupid things that make them not work with Smoothie when they really should. Easy to fix if you can code though ).
I love Octoprint. It’s for 3D printers, but it’s pretty good for any machine.
Smoothie also has Ethernet support and it’s own ( simple ) web interface.
On my CNC mill I personally drag/drop the gcode file to the Smoothie, then using a serial terminal just type “play /sd/myfile.gcode”
Cheers
