Funny willingly wobbling tool for CNC, to find edges. Some are $3 worth on ebay so I buy one "just in case"™. Learning everyday
https://www.youtube.com/watch?v=5_qiPE5z7SE
I also would like to use an edge finder, but the CNC I have on order will take an ER11 collet… I can’t find any affordable edge finders with a small enough shaft for this. Largest collet I could find for ER11 is 5/16".
@Jason_Frazier turn the edge finder?
Interesting idea. I don’t have a lathe, much less a hard steel lathe of the precision needed to keep the edge finder working well after being turned. Maybe I’ll ask around.
@Jason_Frazier idem, the next big tool to have at home (or is it a laser cutter? – then I will be a fablab at home!). Now, the metal of these low cost versions may not be hardened, who knows?
@Jason_Frazier One cheap alternative:
http://www.sherline.com/pages/tips/tip29.htm
Also, they do make 1/4" shaft “springy” ones:
http://www.pts-tools.com/cgi/CGP2SRIM?PMITEM=NG49A250&PARTPG=CGP2SRFC&PAMENU=Content-type:%20text/html
Thanks for those links!
