Further information for the maximum mA debate. Quality tubes can run at high mA.
Quality tubes can run at high mA. Here are the specs on a Sinjoe 80W tube:
TECHNICAL SPECIFICATIONS
Power: 80-90 watts
Operating Current: 26-29 mA
Max Current: 30 mA
LifeSpan: 10,000 hours at <28mA
Diameter: 80mm (3.2 inches)
Length: 12400mm (49 inches)
Humidity 10-60 percent
Warranty: 12 months
Notice that the lifespan is 10,000 hours at 27 and under mA (Which is running at 90% power or less)
And for a Reci 80W tube:
Power: rated 80 watts; Maximum 90 watts
Operating Current: 25-27 mA
Max Current: 30 mA
Length: 1250mm (49 inches)
Warranty: 12 months
Notice you can run the Reci tube at 100% power and still have an estimated 10,000 hours lifespan. This tube is on sale at http://laser-depot-usa.com/reci-w1-80w-1200mm-laser-tube-free-shipping for $450.00 (Use coupon code 50off). Shipping is free.
Cost per hour to replace the tube is:
4.5 cents per hour.
Think how much more money you can be making running at higher mA, therefor faster cutting speeds and less passes.
So why would you want to max your power out at 8mA???
Not all tubes are created equal! (obvious statement)
I buy cheap when I know I will not be using it a long time. That is why I started with a K40 and then upgraded to a better laser. I will be upgrading the tube to a RECI when the one in my new one fails. I just had to justify the cost.
RECI tubes are nice and they provide good reliable data on the tube. I wish other tubes did the same.
Cheap Chinese tubes won’t give you that data and the info they do give is suspect. Even the wattage of the tube is almost always overstated - might be what the tube can deliver when overpowered but not what you’d see when you’re using it in real life with an eye to keeping it running for more than a few hours.
Cloudray and Sinjoi are pretty reliable as well. FYI, everything is on for 50% off at laser depot usa right now (Prices appear artificially inflated though) After the discount the price is actually pretty good, with free shipping. They have some nice RECI tubes available right now.
