G3 code not supported by SmoothieBoard ?
Hello, I’m having trouble using the G3 code (counter-clockwise motion). I’ve used the G2 code on several occasions in our test runs and no problems occurred. But when using the G3 code, simply nothing happens.
I’m using the PrintRun interface to execute some test files, and either if I’m running a script or simply entering the G3 code in the command bar in the interface, nothing happens. No error message, platform doesn’t freeze up, nothing. It stays on “SENDING G3 xxxx”. I can still work with the platform after so it’s definitely not a locking up problem. I’ve tried many combinations of what I’ve seen throughout forums and sites i.e. G3 X50 R10, G3 X50 I10, G3 X50 J10.
I’ve seen some sites stating using G17 instead. But I can’t get it to work either.
Anyone might know if indeed it’s simply not supported (even though it’s mentioned in the supported G-codes of Smoothieware) or I’m simply doing something wrong.
Thanks
is this with a delta or Cartesian?
