G30 Command on Delta
Hi all,
When i send the G30 command to find the bed, the axis start moving very slowly toward the surface, and this take forever…
is there any G-code sequence i cas send to get the axis moving fast till 10mm before the surface and then go slowly to find the surface?
EX: G0 Z10:G30
Will that work? Or the G30 has to be counted from the Zero position?
Don’t know is i made this clear enough…
Thanks for any advise
Yes it will work, that is what G0 does
Thank you so much!!
