G31 translated off bed
Hello all, I am running a large Delta printer with an Azteeg X5 Mini V3 board from a Windows 10 Computer. Whenever I issue the grid probe command (G31) my printer attempts to probe points that are off of the bed at the start of the routine, then skips other parts of the bed near the end of the routine, almost as if the grid has somehow been translated backwards on my bed. Any ideas on what is causing this issue and possible fixes would be much appreciated.
[[code]]# Robot module configurations : general handling of movement G-codes and slicing into moves
arm_solution linear_delta # delta selection
arm_length 490 # this is the length of an arm from hinge to hinge
arm_radius 330 # this is the horiontal distance from hinge to hinge when the effector is centered
default_feed_rate 4000 # Default rate ( mm/minute ) for G1/G2/G3 moves
default_seek_rate 4000 # Default rate ( mm/minute ) for G0 moves
mm_per_arc_segment 0.0 # Fixed length for line segments that divide arcs 0 to disable
mm_max_arc_error 0.01 # The maximum error for line segments that divide arcs 0 to disable
# note it is invalid for both the above be 0
# if both are used, will use largest segment length based on radius
#mm_per_line_segment 5 # Lines can be cut into segments ( not usefull with cartesian coordinates robots ).
delta_segments_per_second 100 # segments per second used for deltas
  1. Arm solution configuration : Cartesian robot. Translates mm positions into stepper positions
alpha_steps_per_mm 640 # Steps per mm for alpha stepper
beta_steps_per_mm 640 # Steps per mm for beta stepper
gamma_steps_per_mm 640 # Steps per mm for gamma stepper
  1. Planner module configuration : Look-ahead and acceleration configuration
planner_queue_size 32 # DO NOT CHANGE THIS UNLESS YOU KNOW EXACTLY WHAT YOUR ARE DOING
acceleration 1000 # Acceleration in mm/second/second.
junction_deviation 0.03 # Similar to the old "max_jerk", in millimeters, see :
# and . Lower values mean being more careful, higher values means being faster and have more jerk
  1. Stepper module configuration
microseconds_per_step_pulse 1 # Duration of step pulses to stepper drivers, in microseconds
base_stepping_frequency 100000 # Base frequency for stepping
  1. Stepper module pins ( ports, and pin numbers, appending "!" to the number will invert a pin )
alpha_step_pin 2.0 # Pin for alpha stepper step signal
alpha_dir_pin 0.5 # Pin for alpha stepper direction
alpha_en_pin 0.4 # Pin for alpha enable pin
alpha_current 1.0 # X stepper motor current
alpha_max_rate 30000.0 # mm/min actuator max speed
x_axis_max_speed 30000.0 # mm/min cartesian max speed
beta_step_pin 2.2 # Pin for beta stepper step signal
beta_dir_pin 0.20 # Pin for beta stepper direction
beta_en_pin 0.19 # Pin for beta enable
beta_current 1.0 # Y stepper motor current
beta_max_rate 30000.0 # mm/min
y_axis_max_speed 30000.0 # mm/min
gamma_step_pin 2.3 # Pin for gamma stepper step signal
gamma_dir_pin 0.22 # Pin for gamma stepper direction
gamma_en_pin 0.21 # Pin for gamma enable
gamma_current 1.0 # Z stepper motor current
gamma_max_rate 30000.0 # mm/min
z_axis_max_speed 30000.0 # mm/min
  1. Serial communications configuration ( baud rate default to 9600 if undefined )
uart0.baud_rate 115200 # Baud rate for the default hardware serial port
second_usb_serial_enable false # This enables a second usb serial port (to have both pronterface and a terminal connected)
#msd_disable false # disable the MSD (USB SDCARD) when set to true
#leds_disable true # disable using leds after config loaded
#dfu_enable false # for linux developers, set to true to enable DFU
#watchdog_timeout 10 # watchdog timeout in seconds, default is 10, set to 0 to disable the watchdog
## Extruder module configuration
extruder.hotend.enable true # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend.steps_per_mm 418.5 # Steps per mm for extruder stepper
extruder.hotend.default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend.acceleration 3000 # Acceleration for the stepper motor mm/sec²
extruder.hotend.max_speed 50 # mm/s
extruder.hotend.step_pin 2.1 # Pin for extruder step signal
extruder.hotend.dir_pin 0.11 # Pin for extruder dir signal
extruder.hotend.en_pin 0.10 # Pin for extruder enable signal
  1. extruder offset
#extruder.hotend.x_offset 0 # x offset from origin in mm
#extruder.hotend.y_offset 0 # y offset from origin in mm
#extruder.hotend.z_offset 0 # z offset from origin in mm
  1. firmware retract settings when using G10/G11, these are the defaults if not defined, must be defined for each extruder if not using the defaults
#extruder.hotend.retract_length .5 # retract length in mm
#extruder.hotend.retract_feedrate 15 # retract feedrate in mm/sec
#extruder.hotend.retract_recover_length 0 # additional length for recover
#extruder.hotend.retract_recover_feedrate 8 # recover feedrate in mm/sec (should be less than retract feedrate)
#extruder.hotend.retract_zlift_length 0 # zlift on retract in mm, 0 disables
#extruder.hotend.retract_zlift_feedrate 6000 # zlift feedrate in mm/min (Note mm/min NOT mm/sec)
delta_current .2 # Extruder stepper motor current
  1. Laser module configuration
laser_module_enable false # Whether to activate the laser module at all. All configuration is
# ignored if false.
#laser_module_pin 2.5 # this pin will be PWMed to control the laser. Only P2.0 - P2.5, P1.18, P1.20, P1.21, P1.23, P1.24, P1.26, P3.25, P3.26
# can be used since laser requires hardware PWM
#laser_module_maximum_power 1.0 # this is the maximum duty cycle that will be applied to the laser
#laser_module_minimum_power 0.0 # This is a value just below the minimum duty cycle that keeps the laser
# active without actually burning.
#laser_module_default_power 0.8 # This is the default laser power that will be used for cuts if a power has not been specified. The value is a scale between
# the maximum and minimum power levels specified above
#laser_module_pwm_period 20 # this sets the pwm frequency as the period in microseconds
  1. Hotend temperature control configuration
temperature_control.hotend.enable true # Whether to activate this ( "hotend" ) module at all. All configuration is ignored if false.
temperature_control.hotend.thermistor_pin 0.24 # Pin for the thermistor to read
temperature_control.hotend.heater_pin 2.5 # Pin that controls the heater
temperature_control.hotend.thermistor Semitec # see
#temperature_control.hotend.beta 4066 # or set the beta value
temperature_control.hotend.designator T #
#temperature_control.hotend.max_temp 300 # Set maximum temperature - Will prevent heating above 300 by default
#temperature_control.hotend.min_temp 0 # Set minimum temperature - Will prevent heating below 0 by default
  1. safety control is enabled by default and can be overidden here, the values show the defaults
#temperature_control.hotend.runaway_heating_timeout 900 # max is 2040 seconds, how long it can take to heat up
#temperature_control.hotend.runaway_cooling_timeout 0 # max is 2040 seconds, how long it can take to cool down if temp is set lower
temperature_control.hotend.runaway_range 20 # Max setting is 63°C
#P39.98 I5.00 D79.91
  1. temperature_control.hotend.p_factor 20.9 #
  2. temperature_control.hotend.i_factor 1.108 #
  3. temperature_control.hotend.d_factor 99 #
  1. For bed
temperature_control.bed.enable true # Whether to activate this ( "hotend" ) module at all.
temperature_control.bed.thermistor_pin 0.23 # Pin for the thermistor to read
temperature_control.bed.heater_pin 1.25 # Pin that controls the heater
temperature_control.bed.thermistor Honeywell100K # See
#temperature_control.bed.beta 3950 # Or set the beta value
temperature_control.bed.set_m_code 140 # M-code to set the temperature for this module
temperature_control.bed.set_and_wait_m_code 190 # M-code to set-and-wait for this module
temperature_control.bed.designator B # Designator letter for this module
  1. Bang-bang ( simplified ) control
  2. See
temperature_control.bed.bang_bang true # Set to true to use bang bang control rather than PID
temperature_control.bed.hysteresis 5.0 # Set to the temperature in degrees C to use as hysteresis
  1. Switch module for fan control
switch.fan.enable true #
switch.fan.input_on_command M106 #
switch.fan.input_off_command M107 #
switch.fan.output_pin 2.4 #
switch.fan.max_pwm 210
  1. automatically toggle a switch at a specified temperature. Different ones of these may be defined to monitor different temperatures and switch different swithxes
  2. useful to turn on a fan or water pump to cool the hotend
#temperatureswitch.hotend.enable true #
#temperatureswitch.hotend.designator T # first character of the temperature control designator to use as the temperature sensor to monitor
#temperatureswitch.hotend.switch misc # select which switch to use, matches the name of the defined switch
#temperatureswitch.hotend.threshold_temp 60.0 # temperature to turn on (if rising) or off the switch
#temperatureswitch.hotend.heatup_poll 15 # poll heatup at 15 sec intervals
#temperatureswitch.hotend.cooldown_poll 60 # poll cooldown at 60 sec intervals
  1. switch.psu.enable true # turn atx on/off
  2. switch.psu.input_on_command M80 #
  3. switch.psu.input_off_command M81 #
  4. switch.psu.output_pin 2.13o! # open drain, inverted
  1. Switch module for spindle control
#switch.spindle.enable false #
  1. Endstops
endstops_enable true # the endstop module is enabled by default and can be disabled here
delta_homing true # forces all three axis to home a the same time regardless of what is specified in G28
alpha_max_endstop 1.24^ #
alpha_homing_direction home_to_max # or set to home_to_max and set alpha_max
alpha_min 0 # this gets loaded after homing when home_to_min is set
alpha_max 0 # this gets loaded after homing when home_to_max is set
beta_max_endstop 1.26^ #
beta_homing_direction home_to_max #
beta_min 0 #
beta_max 0 #
gamma_max_endstop 1.28^ #
gamma_homing_direction home_to_max #
gamma_min 0 #
gamma_max 430 # change to suit your height
alpha_max_travel 1000 # max travel in mm for alpha/X axis when homing
beta_max_travel 1000 # max travel in mm for beta/Y axis when homing
gamma_max_travel 1000 # max travel in mm for gamma/Z axis when homing
#probe endstop
#probe_pin 1.29 # optional pin for probe
alpha_fast_homing_rate_mm_s 200 # feedrates in mm/second
beta_fast_homing_rate_mm_s 200 # "
gamma_fast_homing_rate_mm_s 200 # "
alpha_slow_homing_rate_mm_s 20 # "
beta_slow_homing_rate_mm_s 20 # "
gamma_slow_homing_rate_mm_s 20 # "
alpha_homing_retract_mm 5 # distance in mm
beta_homing_retract_mm 5 # "
gamma_homing_retract_mm 5 # "
alpha_trim 0 # software trim for alpha stepper endstop (in mm) - moves down
beta_trim 0 # software trim for beta stepper endstop (in mm)
gamma_trim 0 # software trim for gamma stepper endstop (in mm)
  1. optional enable limit switches, actions will stop if any enabled limit switch is triggered
#alpha_limit_enable false # set to true to enable X min and max limit switches
#beta_limit_enable false # set to true to enable Y min and max limit switches
#gamma_limit_enable false # set to true to enable Z min and max limit switches
#move_to_origin_after_home true # move XY to 0,0 after homing
  1. optional Z probe
zprobe.enable true # set to true to enable a zprobe
zprobe.probe_pin 1.29^ # pin probe is attached to if NC remove the !
zprobe.slow_feedrate 5 # mm/sec probe feed rate
#zprobe.debounce_count 100 # set if noisy
zprobe.fast_feedrate 100 # move feedrate
zprobe.probe_height 35 # how much above bed to start probe
leveling-strategy.delta-calibration.enable true # basic delta calibration
leveling-strategy.delta-calibration.radius 120 # the probe radius
  1. associated with zprobe the leveling strategy to use
leveling-strategy.delta-grid.enable true # basic delta calibration
leveling-strategy.delta-grid.radius 150 # the probe radius
leveling-strategy.delta-grid.size 11
leveling-strategy.delta-grid.initial_height 35
leveling-strategy.delta-calibration.initial_height 35
leveling-strategy.delta-grid.save true
  1. kill button (used to be called pause) maybe assigned to a different pin, set to the onboard pin by default
kill_button_enable true # set to true to enable a kill button
kill_button_pin 2.12 # kill button pin. default is same as pause button 2.12 (2.11 is another good choice)
  1. Panel See
panel.enable false # set to true to enable the panel code
  1. Example viki2 config for an azteeg miniV2 with IDC cable
panel.lcd viki2 # set type of panel
panel.spi_channel 0 # set spi channel to use P0_18,P0_15 MOSI,SCLK
panel.spi_cs_pin 0.16 # set spi chip select
panel.encoder_a_pin 3.25!^ # encoder pin
panel.encoder_b_pin 3.26!^ # encoder pin
panel.click_button_pin 2.11!^ # click button
panel.a0_pin 2.6 # st7565 needs an a0
#panel.contrast 8 # override contrast setting (default is 9)
#panel.encoder_resolution 4 # override number of clicks to move 1 item (default is 4)
#panel.button_pause_pin 1.30^ # kill/pause set one of these for the auxilliary button on viki2
#panel.back_button_pin 1.30!^ # back button recommended to use this on EXP1
panel.buzz_pin 0.25 # pin for buzzer on EXP2
panel.red_led_pin 2.8 # pin for red led on viki2 on EXP1
panel.blue_led_pin 4.29 # pin for blue led on viki2 on EXP1
panel.external_sd true # set to true if there is an extrernal sdcard on the panel
panel.external_sd.spi_channel 0 # set spi channel the sdcard is on
panel.external_sd.spi_cs_pin 1.23 # set spi chip select for the sdcard
panel.external_sd.sdcd_pin 1.31!^ # sd detect signal (set to nc if no sdcard detect)
panel.menu_offset 1 # some panels will need 1 here
  1. Example mini viki2 config
#panel.lcd mini_viki2 # set type of panel
#panel.spi_channel 0 # set spi channel to use P0_18,P0_15 MOSI,SCLK
#panel.spi_cs_pin 0.16 # set spi chip select
#panel.encoder_a_pin 3.25!^ # encoder pin
#panel.encoder_b_pin 3.26!^ # encoder pin
#panel.click_button_pin 2.11!^ # click button
#panel.a0_pin 2.6 # st7565 needs an a0
##panel.contrast 18 # override contrast setting (default is 18)
##panel.encoder_resolution 2 # override number of clicks to move 1 item (default is 2)
#panel.menu_offset 1 # here controls how sensitive the menu is. some panels will need 1
panel.gamma_jog_feedrate 200 # z jogging feedrate in mm/min
panel.hotend_temperature 185 # temp to set hotend when preheat is selected
panel.bed_temperature 60 # temp to set bed when preheat is selected
network.enable true # enable the ethernet network services
network.webserver.enable true # enable the webserver
network.telnet.enable true # enable the telnet server
network.plan9.enable true # enable the plan9 network filesystem
network.ip_address 192.168.0.106 # the IP address
network.hostname BigD
  1. Azteeg specific settings do not change
currentcontrol_module_enable true #
digipot_max_current 2.0 # max current
digipot_factor 113.5 # factor for converting current to digipot value
[[/code]]
