Hi,
Im new to smoothieware and im trying to dial in my delta. I ran through both calibrations but G31 consistently has one side of the bed too high.
Since the height calibration is also not part of G32 I was wondering if I get bad tilt correction if G32 is not perfect or if there are other issues like G31 not being reliable.
Cheers
There are no G32/G31 interraction problems, and no problems with G31 not being reliable or anything like that.
What’s happening here is probably that your machine has a defect that the calibration doesn’t handle, like a tower being slanted, or a tower being farther from the center than the others.
I see, in the mean time with same manual endstop correction after the G32 I managed to get reasonable result. But ill do some mechanical troubleshooting. Thanks for the fast response.
