G32 error
When I run a G32, the printer performs several cycles of probing and homing, but then, it tries to run all three actuators up through the end stops. I tried doing an M18, after the G32, to shut off the motors, but it seems that the calibration has not finished yet, when the head-stop-ram happens.
What do I have to do to get G32 to complete successfully?
Can I tell the smoothie to turn on and use the end stops, any time the motors are moving?
Hey.
Do you have gamma_max set ?
Does homing with G28 work correctly ?
Can we see your config file ?
Cheers.
