Geetech RUMBA with MKS mini 12864
Hi all,
I recently bought a Geetech RUMBA. I am trying to connect with MKS mini 12864. It is showing only a white screen. I interchanged Exp1 and Exp2 also. No result.
In one Github post, someone has suggested adding the below lines for MKS 12864.
#define DOGLCD_CS 38
#define DOGLCD_A0 41
I tried adding those lines. But no results. Please help
Thanks
The issue is solved. Actually the Reset button in the LCD was pressing against the front cover. Added extra spacer. Now working fine.
