Hi,
I’ve gotten myself a AZSMZ board and installed the latest smoothie firmware, which is based on the same CPU.
I’ve set up my thermistor with the rt curves.
I’m using a thermistor which has about 4 700 000 Ω at room temperature. When testing the board, I have no readings.
When I plug a 2 000 000 Ω pot, I can see the temperature rising starting at 55°C, which is equivalent to 1 700 000 Ω. Below this, there are no readings.
I was able to get it to work with ATMEL based boards, and I thought it would be easier with a 12 bits ADC. Is my problem hardware related or firmware related? I cannot see any error message when going under 55°C, only nothing.
Any help will be greatly appreciated!
Hey.
For problems related to the AZSMZ, you might want to go to the seller rather than to the community.
The AZSMZ is not Open-Source and is not connected to this community, so people are less likely to be willing to help.
Hope you’ll figure out your problem.
Cheers.
Hi Arthur,
I first wanted to get a SmoothieBoard, but it seems like the supplier Uberclock has been out of stock for quite some time. While searching on the net, I couldn’t find anything that would offer a great deal plus shipping. This is why I have chosen the AZSMZ board.
Also, I have a ZASMZ_mini which seems to be open-source: reprap org/wiki/AZSMZ_Mini
Regards,
Hey.
Yeah, Uberclock has been out of stock recently. They are back in stock now I think. You can also get boards at the hackaday store, robotseed, and a few other places.
The AZSMZ mini isn’t open-source : the reprap wiki admin have tried to get them to clarify the situation about the license, and it’s been a mess. When they didn’t release the files, they said it’s GPL, but when they released the files they attached a non-open-source license. They essentially don’t want the board to be open-source, but try to make it look like it is so it can be on the Reprap Wiki ( which is a very good source of traffic ).
About your problem : do you have the most recent firmware version ? Have you tried another thermistor input ?
Cheers.
