Hello, i am a new smoothie user.
I bought the board from robotseed incl the GLCD adapterboard.
1:
I can’t get the display to work. It works on my rampsboard.
I have soldered the little jumper on the adapterboard, soldered all headers on mainboard, i tried a TO220 7805 (1.5A) as i just ordered the 0.5A with the board.
The 7805 gets really hot (yes it is connected correct). The 0.5A also gets hot when used.
The display just have background light, and beeps when the dial is pressed.
I have used the recommended config for the display.
2
I am running it on a delta, and all axes works. After homing and on my way down to the buildplate, i can jog all towers all the way to the bottom
below 0. I have a build height of 614mm (big delta)
Gamma_max is set to 614
When run on Ramps, i could never go past 0 (avoiding headcrash).
Is there a Gamma_min i have missed?
3
The sd card gets corrupted all too easy i think. It seems all power must be off to remove it, not just the usb cable.
Or am i doing something wrong?
4
It’s very hard to connect to the board. Simplify 3d is easiest. RepetierHost has big problems connecting, it takes forever and most of the time
it respond that there is no comport.
Seems like all eventually connect, but only after several minutes.
Beginners (un)luck ?
