Going mad this afternoon. Been a while since I messed with my Eustathios, yesterday got a PEI sheet laminated to my glass and ran through tramming the bed with the piece of paper and many repetitions method.
Went to do some prints this morning, and I notice that the first layer is excessively squished. Now I measured the paper I trammed the bed with to 0.1mm so I set the Global G-Code offset in the Z-Axis in Simplify 3D to -0.1mm to compensate. This should in theory mean that a zero in the slider will result in the head being precisely at the surface of the PEI right?
Checking the gcode I see that the first layer is being printed at Z0.092mm as I would expect, meaning total distance of the head is 0.192mm from the bed (my layer height). However the first layer is clearly way too close to the bed.
Obviously I can just mess with my Z-Axis offset to fix this, but I’m trying to understand where my logic has failed here. Any ideas?
