Good Afternoon Arthur, I am not an expert on G32 results,
Good Afternoon
Arthur, I am not an expert on G32 results, how whacked is this reading below ?Thanks
Connecting…
Printer is now online.
Using tool 0.
G32
SENDING:G32
Calibrating Endstops: target 0.030000mm, radius 120.000000mm
set trim to X:0.000000 Y:0.000000 Z:0.000000
initial Bed ht is 591.162476 mm
T1-0 Z:4.7375 C:379
T2-0 Z:4.8875 C:391
T3-0 Z:5.2750 C:422
set trim to X:0.000000 Y:-0.187830 Z:-0.673057
T1-1 Z:4.9625 C:397
T2-1 Z:4.9750 C:398
T3-1 Z:5.0500 C:404
set trim to X:0.000000 Y:-0.203482 Z:-0.782625
T1-2 Z:5.0000 C:400
T2-2 Z:5.0250 C:402
T3-2 Z:5.0875 C:407
set trim to X:0.000000 Y:-0.234787 Z:-0.892193
T1-3 Z:5.0375 C:403
T2-3 Z:5.0250 C:402
T3-3 Z:4.9875 C:399
set trim to X:-0.062610 Y:-0.281744 Z:-0.892193
T1-4 Z:5.0250 C:402
T2-4 Z:5.0250 C:402
T3-4 Z:4.9875 C:399
set trim to X:-0.109567 Y:-0.328702 Z:-0.892193
T1-5 Z:5.0250 C:402
T2-5 Z:5.0125 C:401
T3-5 Z:5.0375 C:403
trim set to within required parameters: delta 0.025000
Calibrating delta radius: target 0.030000, radius 120.000000
initial Bed ht is 591.212463 mm
CT Z:5.000 C:400
T1-1 Z:4.950 C:396
T2-1 Z:4.950 C:396
T3-1 Z:5.225 C:418
C-1 Z-ave:5.0417 delta: -0.042
Setting delta radius to: 204.6708
T1-2 Z:4.938 C:395
T2-2 Z:4.938 C:395
T3-2 Z:4.988 C:399
C-2 Z-ave:4.9542 delta: 0.046
Setting delta radius to: 204.7854
T1-3 Z:4.963 C:397
T2-3 Z:4.975 C:398
T3-3 Z:5.037 C:403
C-3 Z-ave:4.9917 delta: 0.008
Calibration complete, save settings with M500
I think that looks reasonably ok. What kind of probe are you using ?
I’m not really the one to tell you if those are good results or not : tests should tell you that.
Cheers.
ah ok, sorry my old age is getting to me…BLTouch on Smoothie 5x, I will read a bit more, thanks again
