Good Friends I have problems with my machine k40 . I do not want to cut 3mm MDF , I have to pass it 3 times. And clean your mirrors and check the grounding .
And I also repeat the previous action
Try checking the lens is clean and positioned correctly. And also you should check your focus height. Mine as standard needed to be raised by 3mm
agreed with david, set focus, and air assist for thick wood is a plus.
If you are planning on cutting any thicker materials at more than a snails pace you need the air assist. Before I added it to mine I could not cut 1/4" ply in less than 5 or 6 passes at 1 mm/s, after I added the assist I could cut 1/4" ply in one pass at about 5 mm/s.
ah ok esta look , right now the machine has trouble Let me UN tube laser reflects the laser was not in the best SUCH any sales mirrors the laser tube
